Neoware E100 Thin Client Factory Restore Help!
Jasonx82
I purchased 5 used Neoware E100 Thin Clients from Ebay. I'm currently trying to factory restore them but there is an admin password thats on them which wont allow me to make any kind of changes without it.
Does anyone know how to bypass or reset/Factory Restore the thin client?
Mods: Sorry if this is the wrong section.
Thanks in advance
Jason
Hold down Shift while it's booting. Can you get to the LILO boot prompt, or does the password prompt occur before that? If you can get to LILO, bring it up in single user mode and change the password there.
