Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
See my rig.
With some water cooling (pump, etc..) and 2 or 3 more HDD. Will my power supply be able to put enought power? I bought this one because every review gave it 10/10 and it was pretty costly.
The NeoPower is a full ATX 12V 2.0 compliant unit, including dual +12 rails. With 33A on +12 combined, you'll be good to go unless you're running a dozen hard drives, an overclocked P4 emergency edition, an SLI setup with voltmodded 6800 Ultras, and enough lights and fans for a show on the Las Vegas strip.
My +12 line starts at 11.63 volts and goes down from there causing lock ups. After reading several reviews on the PS it seems the overwhelming concern is the low 12 Volt line. I love the modular cables but I cant run my system with it.
I would love to hear if anyone is having luck with PS on a similiar system. At this point I am going to have to send this PS back and I am thinking of going with the ThermalTake Silent Pure Power 680
