I just got this PSU from ZZF. It works just fine with my old testbed, a P4 1.7. When I hook it up to my DFI NF4 Ultra-D, the board only boots one out of four times, if I'm lucky. The failed boots do either of two things- the LEDs all flicker and then turn off, or it stays stuck in the initial, four-light phase. I've done everything:
1) Taken out of case
2) Put back in case
3) Tested video in every slot
4) Taken out video completely
5) Tested board on paper on floor, no case
6) Reseated plugs, RAM, etc.
The only thing that's changed in my setup was my PSU, which used to be a ModStream 520W. It worked beautifully then, and I had it running out of a case- I didn't even move it when I swapped supplies! I don't have a backup to test, but the board is still good- it boots one out of four times, and nothing moved when I unhooked my old power supply and hooked up the Antec.
I seriously think the NeoHE is incompatible with DFI boards now, as well as the documented dislike for Asus. Can anyone else chime in?
2) Put back in case
