Neo4 SLI Hang
Well I've had the MSI Neo4 Platinum for almost a year now and just getting to OC'n it but having some problems. Im using a 3000+ Winchester, (single) MSI NX6600GT, 2x1 Gig Corsair XMS TWINX2048-3200PRO and 10k WD Raptor. I can get this chip to run at 238fsb with NO voltage increases to anything and the system runs stable and restarts fine, if i bump it to 240fsb the monitor wont turn on. I have increased the vcore to max 1.55, increased chipset voltage to max 1.85 decreased the HTT to 3-4, ive seen multipliers at 10 on some ppls post but mine maxes at 9 and thats where i usually leave it, and the monitor still wont come on. Ive tryed playing a bit with the memory timing but havent dug to far into it. Stock timing on this ram (according to Newegg spec info) is 3-3-3-8 at 2.60, but ive never gotten the computer to boot running at suggested voltage. When I overclocked to 245fsb prime95 found no errors but when i did a soft restart the monitor wouldnt come back on and had to hit the bios reset. Could use some suggestions. The problem im finding is no matter what I increase or decrease the monitor wont come on at reset. Making it very hard to diagnose exactly what it is I need to do. Also heat is not an issue odd thing is at 250 it was still running at 34C on air. I also did a Aquamark3 test just now and I got a better score at 238 with stock voltages than I did when I was trying to OC past 245...very interesting.
