Neo2 Platinum HANGS on boot
seancky2
Ok this has been happening every once in a while, what happens is sometimes when i reboot the system will hang at the Realtex Rtl8115..... boot agent part (you know the part after it detects all the drives and stuff) well usualy what i do to fix it is just remove the memory and put it back in and that does the trick. Well today it didnt work and i reset the memory countless times and still would do it! If you have this board and you know what im talking about it hangs like on the 5th dot, but sometimes it will go to the 6th. Also when i try to go into the bios the system just craps out and my monitor says it is "Out of range".
Miraculously it just booted after i let it sit for 5 minutes and im afraid to reboot again! Does anyone know what is going on!!??
Is it overclocked? IF so your system could be having issues with booting. Also RAM config and timings are important...
