I would like to know if i should keep the onboard audio on the neo 2 or go get something else. my audigy 2 will not work no matter what i do, everytime i try to use it it hoses the system. the onboard audio sounds pretty good for music, i will be doing some gaming also. so if anyone can tell me what they think should i stick with the onboard audio or go with something else if so could you reccomend something.
Thanks in advance
Thanks in advance
