defiant007
- Feb 27, 2006
10-20% would be a nice improvement, nearly 200% is not realistic!
Intel has said that the jump from Core2 Duo -> Nehalem is significantly greater than the jump from P4 -> Core2 Duo.I highly doubt that's real. That means a 100% increase in floating point operations. Intel's pretty damn good, but not that good.
I suspect that benchmark is real, but it is also misleading. Remember, one of the main benefits of Nehalem is that it can distribute single-threaded tasks over more than one core using dynamic multithreading. Current Intel CPUs can't do that. Current Intel CPUs can only use one core for that test.
Thats what I was thinking.
SuperPi currently only uses 1 core, if Nehalem can break up single threaded tasks like its supposed to. (like reverse hyperthreading) That would make perfect sense to be 200% faster in a normally single threaded app. And since most apps are single threaded & don't take advantage of the 2nd, or 3rd & 4th cores of Core 2, this would be a HUGE improvement.
Nahalem is not supported for v1.3
Yeah I know that. But why would they use an older version? Hmmm...![]()
I'm calling BS... At 2.66ghz... no f'n way... I mean the E8500 at 5ghz is just reaching those superpi speeds... I don't see how this could be.
The screenshot is probably taken at idle mode. The SuperPI was probably run at x10 multiplier and not x6 in the screenshot, which would make it ~4.4ghz. Screenshot might be fake though
I suspect four cores will be the maximum for a single thread. On Nehalem, each of the four cores has direct access to the L1 cache on the other three cores. But you don't have that access across separate dies.If this dynamic multi-threading is true than hot damn, Nehalem is going to be a freaking beast! Im curious how many cores/HT's can it use to one a single thread? Because I mean it has 4 cores and 4 HT links. I mean just thinking about what this means for the octocore gets me pretty happy in the pants. Cant wait until more info on Nehalem gets released as we near its launch date.
The 'downside' of Nehalem is that developers will have less incentive to update their applications to make full use of more than two cores. That could hurt owners of existing quad-core CPUs from Intel and AMD.
There are a half-dozen or so documents about it scattered throughout Intel's site. Here is one.I must ask something : where did this BS about reverse HT ( take 2 ) come from ?
There's no such thing.
They call it dynamic multithreading, not reverse multithreading. The processor creates multiple threads from a single thread.
That was not the last presentation, just one I found that had a full PDF. Other presentations were made as recently as 2002-2003.And what do research papers from 1998 have in common with Nehalem ?
Where does it say that Nehalem implements such a technology ?
