Negative LOD Bias Help....
darthanakin23
I have two 6800Ultra's and was wondering what should I set my Negative LOD Bias? Should I put it to Clamped or Allow? Thank you!
Specs:
A8n-SLI Deluxe motherboard
FX-55 @stock
2 gigs of Corsair XMS RAM
2x74 hard drives in RAID0
2x6800Ultra OC's in SLI
Audigy 2ZS Platinum
Depends on your personal preference. If you want to maintain the best image quality at all times, then go with clamped. If you want the option to squish the mips in real close (and get a little extra performance at the expense of a lot of image quality) then set it to allow. I would personally set it to clamped since you've got so much graphics horsepower there anyway.
A lod bias just offsets the mipmap stages, a large negative lod bias will kill the benefits of mipmapping. Most people dont ever change the lod (if the game even gives you the option) so ethier setting wont make a noticeable difference.
