Need your advice with a new build!
bbp
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? Etc
PC will be mostly for PC games. I play a lot of Team Fortress 2 but intend on playing other graphic intensive FPS and some RTS's like Dawn of War II. There will be some Photoshop as well as streaming HD video to a PS3. I don't need Crysis to run at 50 FPS on max settings but I would like to have something that will be able to handle any new games for the next 2-3 years.
Budget is $800. Could be pushed to $1000 if it is really worth it.
3) Where do you live?
Los Angeles, CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need a case, psu, ram, processor, mobo, hdd, heatsink, sound card?, and video card. I'm not sure about the sound card, I've used onboard sound in the past and haven't had any issues with it. I could go either way with that. My friend has a barely used MSI Radeon 4850 he is willing to sell to me for $75. I know it's a good deal but is that a great card?
I won't be reusing any parts.
6) Will you be overclocking?
No
7) What size monitor do you have or plan to have?
I currently have a 19" but will be upgrading to either a 24 or a 27 in the near future.
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I don't need any special features.
10) Do you already have a legit and reusable/transferable OS key/license?
Yup
What do you guys think I can get for my money?
Well, you could build this...
Core i7 920 Quad - $295
6GB DDR3-1600 (G-Skill) - $160
Gigabyte GA-EX58-UD3R - $200 ($15 MIR)
PC Power & Cooling Silencer 750 Quad Red - $100 ($40 MIR)
Geforce GTX 280 OC (BFG) - $340 (shows $290 in cart... may be a pricing mistake? $35 MIR)
Samsung Spinpoint F1 750GB SATA 7200RPM HDD - $80
LG 22X SATA DVDRW -- $25
Antec 300 case - $50
You'd obviously be over budget. It's $1250 before shipping (~$20) and MIRs (~$90) so you'd be about $150 over budget assuming all three MIRs came back... but that $150 over budget is probably worth it considering it will be the difference between an i7 based LGA1366 system and an LGA775 Core2 duo or quad system. They're both pretty evenly matched, for the moment, but the i7 is going to have greater staying power, and if you're wanting to keep this thing for 2-3 years, it needs staying power.
I've read that i7 doesnt really provide much of a benefit over core 2 duo or quad for gaming unless you have multiple GPUs since most games are single threaded. Is this true?
I can't go over $1000 so i7 might be out of the question just because of price.
It's true for the time being. However, you're wanting a long-term machine. LGA775 is a dead socket. There will be no new processors on it from here forward, so the best you're ever going to do would be something like the Q9550. That may not be enough in 3 years.
To get within budget on the above build I'd drop down to a GTX 260 or Radeon HD 4870 1GB (don't get the 512MB if you plan on a new display) and 3 or 4GB of RAM.
I agree with silent. There's a microcenter in OC... got a car?
Core i7 920 Quad - $295 -- $230 at MC.
6GB DDR3-1600 (G-Skill) - $160 -- $135 for DDR3-1333. That saves you $90 right there.
MrWizard6600 brings up a good point: How soon in the future (months? years?) are you planning to upgrade your monitor?
If you aren't planning a new monitor purchase within, at the earliest, the next six months, you could choose a relatively inexpensive video card now (for example, the HD4830 would be enough for gaming on your 19" monitor) and time the purchase of the better card for around the same time as you pursue the monitor purchase.
Will it take a much more expensive video card to run lets say Crysis at 70 FPS on a 27" as it would to run Crysis at 70 FPS on a 19"?
Please excuse my ignorance, it's been a long time since I've followed computer tech. Back when I last a built a decent computer we were still using AGP, IDE and didn't have to worry about 27" monitors.
For Crysis? It can bring a dual GTX 280 SLI setup to its knees with its Ultra High visual settings and AA/AF activated.
For a 1920x1200 resolution, at a minimum, you should be looking at the GTX 280 for reasonable gaming (e.g., Crysis at around 30FPS on medium/high settings).
Ok, maybe Crysis was a bad example :p
The recommendation is the same. The minimum I'd recommend for a single card setup at 1920x1200 (which would be the native resolution of a 24, 25, 26, 27, 28" LCD) is a GTX 280 / 285. The Radeon HD 4870 1GB isn't as fast (roughly as fast as a GTX 260).
Ideal would be a GTX 295 or a pair of GTX 280s / 285s in SLI (the 295 is effectively GTX 285 SLI)... but that's another $200-250.
