Need water cooling suggestions...
Dark Abyss
My system has Intel Pentium 4 Prescott LGA775 3.0EGHz CPU and an MSI Neo Platinum i925X Chipset Motherboard. I just built the system and ran into heat problems. Need some suggestions on a good water cooling system. There is a good Thermaltake one I saw, but I don't know how good their water cooling systems are.
I personally want my W/C setup for OC'ing reasons. Ive been reading tons lately and am about to assemble my own. The Sticky at the top of the page says everything. Its not worth it, Id say, to go and buy a prebuilt W/C system thats external. Best to DIY. If youre not up for that, and you dont mind noise, go with a 4 case fans and a XP-120 HSF. It should cure all your cooling needs for less than 60 bucks.
Doing that don't work... I've done it. I'm probably gunna need water cooling. I idle at 66C and get to 73C full load...
reset your heatsink, and make sure you put thermal paste on the chip. I got a 3.6 lga and it goes about 64c load
If your looking for ease of installation and fairly decent results get ye to EXOS!
The ringing in my ear from my Delta seems to be going away :eek:
While not a truck load better than the SLK800 it sure is alot quiter
