Need VERY small mobo
CompMage
Have a ultra small space to work in and need to replace a system board.
Can anyone suggest a mobo that is between 9.6 x 6.5 or smaller
Perfer INTEL 754, but what ever will do.
Perfer DDR1 but again whatever will do.
4 USB port, video must be onboard.
Speed is nice but not needed,
XP compatable
would consider intergraded boards if need be.
Thanks!!
If you can't find a micro-ATX board that small, you may have to venture towards mini-ITX (17cm^2) or even nano-ITZ (12cm^2). Of course that's not that small, as you also have pico-ITX & 3.5" form factor boards, but with mini-ITX you don't HAVE to go fully integrated, there are a couple of pentium M socket boards around.
Hang on, you don't tell us if you're working in inches of centimetres? Makes a big difference!
since the CPU it's self is almost 4cm wide,
INCHES (US STANDARD)
9.6"x6.5"
METRIC (Rest of the world)
24.5cm x 16.5cm
