Need Variable RPM 92mm CPU Fan
PawNtheSandman
I am looking for a 92mm fan with an adjustable knob like the 80mm Smart Fan 2.
The only ones I have found are Thermaltakes but the CFM are VERY low.
I would like the CFM to go as high or higher than 3000CFM.
I think that you mean 3000rpm
The silenx fans are very quiet, and are temperature controlled, therefore the rpms adjust themselves. the 92mm is 14db, and about 45cfm.
For the overclocker, get a delta fan, or vantec tornado (~100cfm, @50db), and then buy a cheapo fan controller from vantec (~$15).
hope this helped
f
I don't want a fan controller, and I don't want one that is automatic by temperature.
I want a 92mm fan with a knob that allows me to change the rpm's.
Plenty of 80mm fans have this, and the 92mm fans I seen with this are case fans with low RPM.
High rpm 92mm fan with controller is what I want.
Easy there Veruca Salt (Obscure movie reference), you sound as if you are about 3 seconds from hitting the floor and throwing a tantrum.
Get a 80mm thermaltake with the speed control, buy the 92mm you want, and mod it. Done.
If I wanted a modded fan, it would have been done and this thread would have never been started.
I think enermax adjustable is as close as you will get. It doesn't have a knob but I think you can still manually control it.
Well, I am sorry that the PC cooling industry was not aware of your specific need of a high CFM 92mm adjustible fan. If you can't find one, then they probably don't make one. I am pretty sure you can use google as good as the next person. If you are looking for some obscure information, I suggest not coming off sounding like a dick. I highly doubt anyone would be willing to help.
So with that being said, I have not seen, nor could not find one. So your option is mod one or stfu. :cool:
I have a few 92mm enermax,they have a speed adjustment-it's tiny, but big enough to turn with a fingernail or small screwdriver.Decent airflow too. :)
