quiksilverx181
- Nov 21, 2003
Ok, so my computer in my sig, well i formatted it, its been several months, so i format, and i get home, and the computer had apparently restarted like normal in between installation, but it was frozen at boot screen (aka where it says "ABIT Engineering, press DEL for setup"... needless to say i tried pressing everything before i just unplugged it to try to re-start. Well, now monitor was in power save, so i opened up the comp, reset the jumpers for the CMOS, and then put everything back in and started up! POOF! It worked! So here i am thinkin im good to go. WELL, now i have restarted twice after that, and BOTH times its gone to power save on monitor, i have to open up the comp to bios reset so that i can get into my comp! WTF! What can i do? I Dont wanna be opening my comp up EVERY TIME i restart!
