Need urgent help on deciding replacement Mobo!
Kasher_Khan
I ordered parts for the following setup last week
AMD Opteron 148 (I got Cabye core)
Abit AN8 SLI NF4
Gksill PC4000 2GB
Evga 7800GT
Antec Neo HE500
WD raptor
Sony optical drive
Sycthe Ninja HSF
Antec p180 case
If you look in this section of the forum you will see that I started a thread to help me out with my mobo troubles. Bottom line is I have tested all my parts and I still can't see any signal on the screen. I have narrowed it down to a bad mobo and already have an RMA from newegg.
The problem is they no longer have this board on their website. I have investes so much time in researching this one motherboard that I am totally oblivious to what DFI and other manufactuerers have to offer. The only other thing they have at newegg from Abit is the
AN8 Ultra NF4 (which is non SLI but I don't care as long as it is similar in performance to my current board - again I am not very happy with my current board)
On the chance that some thing in my setup isn't compatible with this line of boards please suggest a different board (planning serious ocing) also keep in mind that the scythe ninja cooler is huge and needs to be part of the consideration cause of board layout issues. The ram barely clears the back plate on Abit AN8.
I would really appericiate an urgent response.
I got a response from Abit tech support!
They say the Abit AN8 SLI NF4 939 does not support Opteron 148 CPU?
How can I have missed something as obvious as this. Are they correct! Am I the moron here!
PLease tell me what motherboard "would" support an Opteron and is still good for OCing!
