hi guys
im very disperate and need help!
i just build new comp (for the first time) and did everything by the book.
everything vent smooth!
until......
when i turn ON comp i get black screen saying something about phoenix bios,dual processor,etc... and at the end says PRESS DEL for setup or ESC for exit.
Now here problem start!
my keyboard is ON,all lights on board are ON (usually they turn OFF after few seconds), BUT i cant do enything!
It does not respond,pressing any key (ESC or DEL) does not do anything,im just stuck on that blac screen.
Now, i noticed that on screen does not says anything about HD or DVD.Is that normal?
i can see it only detected my processor!.
Only diference i have between this comp and my old one is that new HD i conected via sata cables,and my old HD is using normal cables.
anyone got any idea what it could be?
i really want to save 100 bucks and not take it to frys electronic for repair .
thank u in advance
parts used-
EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard
CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
SATA 300 HARD DRIVE (can this be a problem?)
PSU 500
Also i forgot to say pressing buton on my DVD drive to open it does not work.im not sure if that is also related to my problem
until......
thank u in advance
parts used-
PSU 500
