FramePointer
- Dec 8, 2011
Hi,
I'm currently in the process of upgrading my system. At the moment the system is using 4x7200 RPM 120GB Hard drives. 2 of them are currently in software raid 0 and have fairly mediocre performance (105 MB/s sequential read and write).
I have a crucial M4 64GB ssd also on the way and will be adding in a 320GB 7200 RPM to be a reliable storage drive (to hold data that I don't want to risk by putting on raid 0 arrays).
What I'm wondering now is if it is even worth putting my 4 120GB HDs in raid 0 and using them for running my games and other large applications off or is it better to just invest in a second 64GB crucial M4 and raid 0 the two SSDs and use the SSD for all the applications?
I'm not sure if the performance gained by raiding the 4 mechanical drives is worth the space they take up and the heat they create. Any ideas on what to do?
I'm tempted by the 2 SSDs in raid idea since Intel announced they would soon be supporting trim in raid 0 in their next version of RST. Also two M4s in raid 0 with firmware version 009 are getting read speeds near 1100 MB/s, sounds fun.
My new motherboard has 6 SATA ports (2 of which are SATA III) and hardware raid support (unlike my old one) via the Z68 chipset.
