I am upgrading my PC but i'm not an expert so I need your opinions on whether or not all of the following parts are compatible and good choices for the
money. If you see anything that can be significantly improved for a slightly greater amount of money, please let me know.
BUDGET = 500-550 dollars or LESS
UPGRADES:
MoBo - EPoX EP-9NPA+Ultra - $94
http://www.newegg.com/Product/Product.asp?Item=N82E16813123236
CPU - Athlon64 3000+ Revision E "Venice" core - $120
http://www.newegg.com/Product/Product.asp?Item=N82E16819103537
GPU - eVGA NVIDIA Geforce 6600GT - $135
http://www.newegg.com/Product/Product.asp?Item=N82E16814130214
HDD - Seagate Barracuda 7200.8 250GB 3.5" Serial ATA150 Hard Drive - $86
http://www.newegg.com/Product/Product.asp?Item=N82E16822148065
RAM - Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) - $68
http://www.newegg.com/Product/Product.asp?Item=N82E16820220037
TOTAL = $503
EXISTING PARTS BEING RE-USED:
CDR - Sony 12x/8x/32x
DVD Rom - Lite-On 52x
Sound - Turtle Beach Santa Cruz
Case - Lian Li PC90 w/ 300w PSU
*^It's been a long time but I think the case is a PC-90. Will I need to upgrade or will the mobo fit into it?^*
QUESTIONS:
1- Is it worth it to spend $135 ($68 more) for 2gb worth of patriot memory or would the performance difference between 1gb and 2gb be negligible?
2- Is there a way to set my current IDE HDD as a slave to the SATA drive which I hope to buy? I have about 4,000 mp3s that I do NOT want to lose so it's
important that they are transferred to the new hard drive.
Thanks a lot for information and opinions!
UPGRADES:
TOTAL = $503
QUESTIONS:
