quad3d@work
- Jun 5, 2001
Here is my situation, I have an aging Q6600 hand-built desktop for several years now and I need some advises to build a new semi-gaming desktop.
My current setup:
Actually I just upgraded to 9800GT from a Radeon 1650 Pro few weeks ago (HUGE difference
). Got a deal on it. It was $80 - $30 mailing rebate. So $50 for 9800GT. Last night I purchased another 9800GT with same deal. It was Gigabyte 9800GT 512MB $80 - $30 mailing rebate.
I intend to SLI these two. I'm contemplating shall I upgrade to a newer LGA 775 mobo and re-use everything else I have? (CHEAP!) Or shall I upgrade CPU+Mobo+RAM (DDR3)? (NOT CHEAP!)
I'm trying to keep the cost low. My current setup is quite sufficient and I don't have performance problems. The only game I play daily is Team Fortress 2. And some other misc ones liks Crysis.
I know SLI-ing 2x9800GT gives me the ball park range of a 260 GTX and without DirectX 11. I don't mind.
I see just DDR3 RAM is still quite expensive... 2x2GB hovering around ~$110. If I upgrade the CPU+mobo god knows how much that would cost. If I just want to upgrade the to a newer SLI LGA 775 mobo, can someone give me a decent recommendation? Try to keep under $80~$100 if possible. If you recommend I upgrade to the newer AMD or Intel setup using DDR3, can you also give me some good cheap recommendations as well?
- Quadcore
- 4GB RAM
- SLI
Thanks!
My current setup:
Intel Q6600 with stock HSF
ECS G31T-M mobo (I know most don't like ECS but I've been using this for 3+ years now. Rock solid no issues whatsoever.)
4GB DDR2 800 (2x2GB) RAM
500GB SATA 7200RPM 16MB HD
eVGA 9800GT 512MB
Antec TruePower TP-650 650W PSU
- Quadcore
- 4GB RAM
- SLI
Thanks!
