Build is:
AMD x64 x2 Dual-Core 6000 Processor
ASUS M2V-MX SE Motherboard
2x1GB Ballistix PC6400 CL4 DDR2
EVGA nVIDIA 8600 GTS 512MB
80 GB SATA 7200 RPM
Some background information:
Built this computer myself. Have never had a problem with the computer. All the cards are seated properly, and the cables are connected properly. 450w powersupply. Main display is a 19' CRT. Also have a TV hooked up to the graphics card via SVIDEO adaptor.
Problem: When I turn my computer on my computer boots fine, but there monitor says "No Signal".
This happened once before, when I moved into my new apartment. I went to hook up the computer for the first time after the move, same thing happens. At the time, all that was plugged in was teh 19' CRT. Once I unpacked my TV, and plugged my Svideo cord into my television and the graphics card, the computer booted up and havent had a problem since. I guess it happen because it was the last known configuration before it was powered down?
Currently.. I have tried multiple different setups, using no SVIDEO TV hookedup, hooking the monitor up to the other DVI port, switching DVI adapters to make sure it isn't broken, everything. Every instinct I have is telling me that the video card is to blame here and that it is nothing to do with the motherboard or any other parts....
Any troubleshooting ideas / advice greatly appreciated.
80 GB SATA 7200 RPM
