Need toggle switch advice
That switch has 2 ON positions. It will work for your application however one direction wouldn't really do anything.
Example: middle is off and whichever direction you choose will be the ON. The other direction will not function unless you want to make that one do something else.
You want a simple ON OFF switch not an ON OFF ON.
Otherwise, the switch is the proper kind.
Oh, I see that now. Thank you for the information.
He can use that 2 position toggle for Reset and Power if he wanted, but yes, a momentary SPST is what you want.
that site doesn't list a SPST Toggle.
This is the type you want,
http://www.amazon.com/Morris-70250-...23079&sr=1-1&keywords=momentary+toggle+switch
EDIT, this is a normally off switch, so this will work for you.
Appreciate it. I take it this switch will also work for a reset as well?
Yep, that will work for reset as well. you will need 2 of them, 1 for the power and 1 for reset, just to be clear.
