Need to upgrade...need some advice here
Solcutter
My vid card took a dive, and my power supply may be doing the same. I have decided on a gtx 280 for an upgrade.
Now I just have to decide on a power supply.
my last one was Silverstone SST-ST60F
http://www.newegg.com/Product/Product.aspx?Item=N82E16817163109
modular, plenty of cables, was happy with it for a long time.
my current setup is:
p5n32-e sli
2g of ddr 800 pc2 6400 ram
2 sata drives
q6600 processor
zalman heatsink
sound blaster x-fi platinum
ive looked on newegg, and i just cant decide on what to go for. as for price, 200 would be the maximum. any pointers appreciated.
If it was my money it would be going to the Corsair 650W or Enermax Modu82+ 625W. Both perform great, but the Enermax is quieter and has modular cabling.
Take a look at the Corsair HX520 and HX620. Either one would be great for your system.
I would get the 620hx Corsair Modular PSU. It will power your PC perfectly and give you some headroom.
You can find a great price on it here.
