So I have a question about setting up dual or quad monitors. Basically I'm trying to setup a system with four 24" monitors. Can I just get a vid card with two DVI outputs to output to two 24" monitors a piece?
The main reason i ask is that on newegg, every vid card I can find says that it's max resolution is 2560x1600. If you put two 1920x1080 monitors side by side that will be 3840x 1080. So.. is that 2560x1600 for the video card with two DVI outputs talking about per screen or total output?
For the four monitors I'll just take whatever it takes to do two monitors then do it again to get the two additional.
So yeah, can I do this with two video cards or do I need four? Also, I wont be doing any hardcore gaming on them so will it matter if the PCI-E vid cards are in 8x slots on the MB instead of 16x?
Thanks for any help!
