Need to replace Mobo/Cpu/Ram Help me out.
AjFreimuth
So my motherboard is finally taking the pooper.
Onboard sound went out a few months ago. Now the USB ports are dead.
So since it's a S939 board I'm gonna be looking at replacing 3 pieces on it.
I'm not apposed to AMD or Intel either one is fine.
Budget is just under 300$ ish.
For an AMD build this is what I tossed together real fast.
Mobo: $100
http://www.newegg.com/product/product.asp?item=N82E16813131022
CPU: $90
http://www.newegg.com/product/product.asp?item=N82E16819103211
Ram: $75
http://www.newegg.com/product/product.asp?item=N82E16820231122
link for the mobo still the amd.
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116036
with the new nehalem cpu's arriving in about 12 months, this setup is my pick for anyone building intel rigs right now, especially anyone upgrading from amd x2's or optys. the allendale 2160 will hit 3ghz with a 333fsb easy, while allowing users to run cheap ddr800 at its stock specs without pushing vdimm or lowering latencies. shipped to norcal for 243 and change.
Ooops updated that.
I don't "Need" SLI ect. So if I can get something cheaper without it to save money then so be it. If i have it then I might use it at some point but not anytime soon.
Also if you can please give input as to your recommendations ect.
