- Dec 2, 2004
Will this switch... http://www.frozencpu.com/products/1838/ele-19/Round_Rocker_Switch.html
...work with this cable...
http://www.frozencpu.com/products/1...tch_Cable_-_2-Pin_Power_SW.html?tl=g4c153s319
... to replace a broken power button on an X-Qpack? Primarily my concern is whether that wire will work with the switch. If not, where can I find a simply power switch? I accidentally yanked the cable contacts off the solder points on my power switch while fiddling with the system... I'm currently using the reset button as a power switch
, but would like to fix this
. Thanks!
