Silverfox1
- Jun 1, 2004
I would like to remove the secondary HD WD 120GB from a PC. The primary C drive is also a 120GB WD and is all that is needed.
Can I simply shut the power down and unplug the atx power connector and the ribbon cable from the Secondary F: drive and then just re-boot the PC ?
Or is the existing ribbon cable used in this rig specifically designed for two HD`s and I will have to get a different ribbon cable for just using the single primary HD as desired?
Intel P4 2.4 GHZ
Thanks for any replys.
Intel P4 2.4 GHZ
