need to know the function of a specific cap
darw_n
My comp fell an enormous distance down a flight of stairs...
the case is totalled, but it did fire up. The only damage to the mobo seems to be a small cap, which is totally missing, located by a USB port that is used for case USB plugs.
since it fired up, seemingly fine, can I determine what that cap is for, and what would happen over time, or what uses it? (in other words, if it is used only by that USB port, can I run the mobo as long as I don't use that port?).
the board is a IT7 maxx
the cap is located directly above the remote USB plug towards the back, towards the bottom, in between PCI 2 & 3, its stamp ID seems to be EC41...
it is not one of the PCI caps, it seems definately to be routed to the USB
Do you have the cap that broke off? If you do, and it is not damaged, you can just solder it back on. If not, and all of the caps around that specific one are the same, you can order a new one and replace it.
Honestly I do not know the effects of leaving the cap off of the mobo, but I would strongly suggest replacing it.
You are lucky that this was the only damage to the hardware itself :p
Oh yeah...that's a cap of protection +2 so youre in rael trouble without it! :D
Don't mind me...I'm drukn. :D LOL
I need to bump this,
does anyone know where to get the info on capacitor functions for specific motherboards?
thanks again
thanks again
Just google for a .pdf file that has the mobo's design on it, and see if one exists. There need to be blueprints somewhere...
