Need to get a DAC. Should I upgrade amplifier as well?
Discussion in 'Computer Audio' started by molson3530, Jul 24, 2017.
  1. molson3530
    molson3530 [H]ard|Gawd
    1,988
    Jul 25, 2004
    As the title says, I need to get a DAC. I recently upgraded my main rig and my old sound card/DAC (ESI Juli@) is no longer compatible. The rest of my gear includes a set of Sennheiser HD-600s powered by a custom PPA amp with an external STEPS power supply. The PPA and STEPS were built by former moderator MisterX 10-12 years ago.
    I am thinking about getting a Schitt Bifrost for a DAC and using my existing amp. Any other suggestions for a DAC or should I look at upgrading my amp as well? I have been out of the loop for quite a while and any input is appreciated.
  2. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    6,097
    Jun 13, 2003
    Any reason you need more than basic DAC functions, i.e. multiple inputs and/or multi-bit support that would necessitate more than a Modi 2 or an Objective2 (ODAC)?
  3. RogueTadhg
    RogueTadhg [H]ard|Gawd
    1,375
    Dec 14, 2011
    The O2 Dac/Amp definitely is really wonderful.
    Although I'm looking into Creative's solution "Sound Blaster Zx" instead. The desktop and mic extension would be helpful.
  4. illram
    illram [H]ard|Gawd
    1,333
    Sep 19, 2011
    Don't waste your money on a bifrost, IMHO. If you just want a neutral accurate conversion get the ODAC.
  5. molson3530
    1,988
    Jul 25, 2004
    Thanks for the suggestions. After looking at some of the reviews I went ahead and ordered a Modi 2 Uber. If I don't like it I will just use the 15 day return window and try the ODAC.
    IdiotInCharge likes this.
  6. IdiotInCharge
    6,097
    Jun 13, 2003
    Main advantage for the Modi 2 Uber over the Objective2 is the optical input, something I wish my O2/ODAC had. This lets you create an electrical gap in the audio chain, and also lets you use a soundcard (likely Creative) for audio processing while still keeping the DAC and Amp stages electrically separate from Creative's hardware.
    termite likes this.
  7. termite
    termite [H]ardness Supreme
    4,504
    Aug 27, 2004
    This is how mine is setup.
    Optical out from a Sound Blaster Z to a Modi 2U. Then out to a headphone amp. I have a Magi 2u, but found the Modi puts out a very clinical sound and have been using a Little Dot I+ for a couple of months.
    The Modi 2U also has an external power source, and is not reliant on USB power.
  8. molson3530
    1,988
    Jul 25, 2004
    I finally got my Modi 2 Uber hooked up and I am quite pleased. I definitely agree that it is very "clinical" sounding, especially paired with my HD600s. I can notice every flaw in my lower resolution or lesser music files even more so than my previous setup. Now I need to find the time to re-rip some of my favorite albums onto my new computer.
