I have a 16 port hub that needs 7.5Volts DC to run, I also have other equipment that I want to power off a Computer PSU, but these items are within the range (12Volt for my ADSL Router)
I know you can get 7.5 by hokking up 12 to + and 5 to negative, but have only seen this done with DC Fans, not much risk when the only thing at stake is a PSU and a fan, but this sounds dodgy to me, and I know you can build a better solution, just wondering what is the best.
My idea was to wire up a few diodes in series with the hub to get the desired 7.5 Volts, but with a 1.7Volt drop per diode, I can't get the desired voltage (6.9 is the closest safe voltage I can get with this solution).
I could research, but if someone knew the solution off the top of thier head it would save me a few hours.
Thanks
Thanks
