Need to find source of problem..
l0cke
A new system I built had been running fine for like 3 months then it stopped displaying images. it has a pci-e graphics card so I tried a normal pci one and it worked fine. It is running with that now but the resolution is pretty bad so I want to get the other one working.
I RMA'd it once and it still does not work. The mobo makes does an error code which I'm pretty sure means "no video card" but my beep timing might be off ;)
So would the mobo be the source of the problem? it is a DFI board. Could there just be some bios setting I'm overlooking? Or should I just RMA the mobo?
Does the fan work on the PCIe card?
Did you update the BIOS right before this happened?
