I was not sure whether to post this under the OS thread or under the Apple products thread. Since I want to reformat my PC and reinstall Windows, I thought it was more appropriate under this thread, but if I was wrong, mods please feel free to move this thread.
My parents have purchased music off of iTunes and like their music collection the way it is. Unfortunately, the PC has had some spyware / viruses in the past which I think I have removed all active threats, but I think the OS was damaged as it is not fast and my dad complains about AOL being too slow (I have tried to explain why but...). Anyway, there's also a lot of junk installed that no one uses anymore and it would be best to start from ground zero -- FDISK and fresh install. I plan to use Knoppix to split the current single hard disk partition into two and install windows from scratch on the second partition, leaving the current install on its own partition and then moving over needed files after the fresh install. Will this plan work with iTunes music library? Can I simply copy all files from the old partition / old OS install to the new partition / new OS install? Anyone see any problems with what I propose or does anyone have a better idea?
