I use windows xp. I have 3 partition on one HD (C (windows), D (my doc) and E (other)) and one partition (F) on an other drive. What I want to do, is to merge the "D" and "E". So far, I moved my doc to the other drive (F). At this point, I do not have the option to format/delete "D", it says it is a system drive. I have the option to format/delete "E" though. I disable system restore on each partition but I still can't format the "D". It is still a "system" drive. How can I make it not a system drive?
Is there something else I could turn off or change the directory of some kind of service that is still stuck on my "D" partition where my doc were?
Thanks
Thanks
