Need to consolidate space....help please
cgram23
I currently own 3 boxes.....2 pc's and one server. My problem is, I'm moving from a house to a 2 bedroom loft, and my space will be limited. All 3 computers will have to be in the same room, linked by a KVM switch. My question is....is there any way to consolidate three computers into one encasement? I was thinking maybe something like a rack mount...but I wasn't sure if they make one's that support an ATX form factor. Any suggestions??
They do make ATX rack mount cases.. however they are not cheap at all. Most of the ones Ive seen are 300-400. You might get lucky and be able to score some used on ebay or something. Then you need to get the rack.. and depending on what you do on that.. it can be 100-2000.
As for consolidating more, have you considered getting some SFF boxes to replace the fullsize machines (if this is even practical for your situation?) This route may be cheaper than putting your systems into a rack.
Can you just get one of the 'stacker' style cases and ditch one or 2 pc's?
Thanks for the ideas, guys. I'm still not sure what I'm going to do...but this gives me a good place to start.
