need to connect L1&L2?
Ripskin
Okay, Ive got an Athlon 2600 and a DFI nfII ultra b. I got it running at 208 fsb X 10 with 1.75 vcore setting.
Everytime I try to go beyond these settings it hangs up and I have to clear the cmos. Id think with 1.75 i could at least get to a x 11 or even 12. Same problem occures at 1.80 vcore.
So Im thinking I need to connect the L1&L2, if I indeed need to do this, what do you recomend using, Ive seen strips you can buy, little kits and other things, is one better to use?
Thanks!
