hey everybody, I am wondering how I can configure 80+ workstations so that they can all reboot before our site backup occurs?
I've tried to test this using task scheduler, created a reboot.bat file with the following code:
shutdown.exe /r /f / t00
pause
i've tried to run that program and it wont run from task scheduler. Our server is running Server2003 if that helps anyway. Would there be an easier way to implement this code on all the units rather then going from computer to computer once I get the batch/script to work?
thank you
pause
thank you
