Need to add extra space to a RAID 5
killerasp
Hey all. I need some help.
I have a HP DL380 with a Smart Array 5i controller. There are a total of 6 drive compartments. They are all filled with 34.6G scsi drives. Problem is that we are running low on space. We have multilple partitions setup on the system. My question are:
1. could we remove one of these drives and replace them with something higher? is it recommended to have different drives in a raid 5 setup?
2. could we mirror all the data and partitions to a machine with the exact same specs but with larger drives?
3. What do you recommend that i do?
thanks.
Does that card have online capacity expansion? If it did, it might be possible to (one at a time) replace the 34G drives with larger drives, let the array rebuild, replace the next one, etc until they are all rebuilt, then use partition magic or some tool to expand the partition (or just make a new one).
You could get a new RAID card, bigger drives, build the array, and find some software to move it all over (ghost perhaps?).
Both are possible, but I have no experience in doing either so I cant recomend one over the other.
Yes, using ghost 9.0 you have the ability to put the EXACT SAME data onto a different drive. You cannot copy registration information, but if it is straight data, ghost works very well.
I think you can format a partition to the same size as the others, but i wouldnt quote me on that one.
But it would be an easy thing to make all the drives bigger (if you are willing to spend the money) and then ghost the old drives onto the new ones
doormat, thats a good idea.
I also have no experience in doing that.
Would anyone else care to throw in their 2 cents?
I'm not quite sure, but I don't think the RAID controller will see anything above the original 34.6gigs when you replace a drive with a larger one. The controller will no doubt rebuild the array, but only use the same ammount of space. Correct me if I'm wrong, but I think the only way you'll be able to do this, is to pull all the data off to a temp space, rebuild a new array with larger drives then restore the data back to the new array.
Whatever you do, just remember to back it up first. My $0.02 for ya.
Based upon my experience, you can expand the capacity of the RAID Array by adding addtional drives but only in increments of the drive size used to create the array.
So, you will need to 1) backup the data 2) install the new larger drives 3) create an array based upon the new larger drive size 3) restore the data to the new larger array.
Well with a Compaq Proliant ML350 that has a Integrated Smart Array Controller, I have twice upgraded the drive size without rebuilding the array.
What I did is replace (one at a time, allowing a full rebuild each time) the drives with larger drives. Then when you are done, you go into the Smart Array Config Util and you will have unalocated space, I added this space to the exsisting array. Then used Server Magic (partition magic for servers) to expand my partitions.
==>Lazn
==>Lazn
have you ever allocated space using microsofts built in tool, MMC disk management plugin?
That will not add the space to the array, but once you have the space added to the array that will let you create more partitions.
You do need to use the HP/Compaq array util to either add the space to the exsisting array, or create a new array with the unallocated space. After that, you can either use Microsofts disk managment to create new partitions, or you can use something like server magic to expand your exsisting partitions.
If you use Microsoft's disk managment before adding the space to the array using the HP/Compaq array util (if it can even see the space, and I am not sure it can) then the space will not be part of a RAID array, and if a drive dies you will lose the data.
==>Lazn
