need tips on an easy to use case...
Eshelmen
I want a case that i can take apart the side door without using stupid screws.... i like the ones where i like pull a latch on the side of the door to do it and it comes out....
anyone reccommend a cheap good one with atleast 420 watt supply?
The Antec Sonata has a side door with a latch, it has thumbscrews in the back but the door will operate on the latch and stay closed without the screws. Most come with a 380W PSU though.
You can get a Chieftec Dragon.
Right now they are 29.97 at Tiger Direct.
Then just buy a PSU for it.
well, you said no screws, lian lis have thumbscrews, but the door stays on pretty well even with only one in a few turns. the doors on chieftechs are cheap as hell, that latch doesnt feel like itll actually hold any force
Well, what I did as a JUST IN CASE.
I bent the top portion of the door.
Now it's a bitch to get off :D
I didn't have a problem with it before, but I had heard someone say something about theirs coming off all the time.
