Need tips for nzxt apollo modding!
ranviper
Hey all.
I want to take apart my NZXT apollo case this weekend and do a little painting and cut a few holes in the mobo tray for cables.
What kind of tips do you have for me to get the best outcome (i.e. types of paint/paint coating, or tools for tray cutting, etc)
Thanks. :D
Hello fellow NZXT gallery member! Good to see you modding.
Here are a few suggestions.
You Should paint the interior white to off set the black case.
A dremal with a cuting blade will work best i think.
Hey thanks for the reply man. White actually sounds good, I feel like it would even brighten the appearance of the LED's as well. I also really wanted to do black, so perhaps a coin toss is in order...
LoL. :D
LoL. :D
Yeah its just kinda a offset of the whole black painted interior trend, and i haven't seen a white interior that didn't look good.
^True true. I think I just may do that then, thanks for flipping my coin =)
Should I use a specific kind of spray paint? Or should a normal brand work?
