signmeuptoo
- Jul 4, 2007
Hey guys, still relatively new 'round here!
I just got a brand new, gorgeous Coolermaster Stacker STC T01 UWK super toward computer case.
Well, I plan on installing a lot of fans (I have my reasons, believe me): I hope to get the crossflow barrel fan, a second 4in3 hard drive module with fan (meaning 2 front 120 mm HD fans), there is the 120 mm rear CPU area fan, the ceiling 80 mm exhaust blowhole fan, the bottom 2 80 mm fan apertures (where the second optional slave supply goes, which I plan on using for a slave supply). I also hope to buy their optional side Window and I want to mod the window to house either 2 250mm fans, or 4 120mm fans.
Naturally, with so many fans, I need them to run slow so I don't go deaf!
But why the hell so many? I live in a place with NO AC, and it is in the South Central USA where it reaches in excess of 100 degrees in my room several days a year. It may be a while before I can get AC, because the room needs to be wired for it and it isn't my home. In fact, the wiring here suxors, sadly. Perhaps I could get an AC unit small enough that it could run on the same circuit as the computer, but I don't know...
So anyways, I need to get 2 devices of front 5.25" bay fan/temp/readout/light controllers. I have some criteria:
I need to control about 7, or maybe 9 or 10 fans total. This means one of the 2 devices will have to be one of the few units out there that will control more than 4 fans. Or I need the devices to be touch enough for a large load so that I could gang two fans on some of the controls.
I'd like to monitor a lot of temps, and I am interested in any units that can handle lots of temperature sensors. I am fine with it having an LCD screen and buttons where I have to cycle through the various temps, where I can't see them all at once. I want a temp sensor for 2 video cards, the CPU, the 2 supplies, 4 zones of the case, and up to 8 HD if even possible. I might even want to monitor some of the motherboard parts, too.
I'd love it if both of them, or one of them could also control lights, say about 4 different lighting units potentially. Over time I would like to have 2 CCFLs and 2 LED/LASER/whatever lights.
Devices that also have other features, such as system information or eSATA are very desirable to me as well.
I would like them to be black or paintable/stainable to black to match my case.
Could you guys give me some suggestions?
