Need system upgrading advice please.
dezimieren
Gaming only.
$500-800 CAD tax + shipping included.
3) Where do you live?
Ontario Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, Motherboard and RAM
I will be reusing my case (thermaltake mid tower), PSU (600w OCZ gameXstream), 2x 500gb western digital drives, Evga gtx260 and optical drives.
6) Will you be overclocking?
Yes, but nothing major.
Using 2x LG 19" LCD's at 1440x900 resolution.
Looking to buy components within the coming week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No special features, although I favour Asus mobo's.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
My question thus is which CPU, Mobo, and RAM to get. Specifically, should I choose an i5 or i7 CPU and how fast/how much RAM is recommended?
Any assistance is greatly appreciated! :D
for gaming only, i5 vs i7 doesn't make a lot of difference, you could get Phenom II and save some considerable cash; quite honestly I'd go that route
memory wise, 4-6GB is fine (depends basically on if you end up with a dual or triple channel system), just match the speed with the processor and keep an eye on volts for i5/i7 builds
