I am uber noob when it comes to audio. Still learning. You've probably seen me post about my dead Klipsch and whatnot.
This is my first and foremost site when it comes to most things techie. I usually try here before I hit AVS. If I should post there instead, lmk. I'll post my questions in list form so it's easier to read/answer if you quote them.
So I have a dead 5.1 Ultra. The amp is dead and it'll cost around $120+shipping to get it fixed. I have the amp right next to me and I can't see any scorched pcbs or busted caps or resistors. The only symptom: plug in power, turn on, fuse explodes and smokes. They are 8" and are linked together by power and ground wires. The bare ends are slotted to plug into the amp.
Can I reuse the two subs?
Is there any way to use them without the amp? How will they be powered? Do they even need power? Speakers just need a signal right?
Do I have to rewire/extend the leads out?
I guess I'd need a receiver for them?
How do I plug that big hole where the amp used to be? What material should I use? The screw holes are still there so I can probably reuse them after piloting the new material.
Should I try to make a new enclosure for them?
Thanks-
Thanks-
