I'm looking for a new motherboard that supports sli, either for a 1900xt, or 2 evga 7800gt's.
I will be air cooling my stystem, with a BIG typhoon heatsinka nd fan, so the placement of things may be a problem.
I was debating between these two:
Msi K8N Diamond SLI:
http://www.newegg.com/Product/Product.asp?Item=N82E16813130037
ASUS A8N32-SLI Deluxe:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131568
I've read revjiews on both boards, and kind of leaning towards the ASUS be cause of the extra pci slot it has. I need to know WTF is the purpose of a pci-4x slot (what goes in there?!?!) and what one would you suggest, if you have had experience with either. The board will be used for a healthy bit of overclocking, but I need Stability first and foremost.
On a side note, im sure everyone here would recommend a single x1900xt on this board rather than 2 nvidia 7800gt's in sli correct?
Thanks!
Thanks!
