Need suggestions
Charger69
Building a new system, working out the price & such with my budget, this is what I have come out with. ( I am looking to spend less than $3000 ).
I will use this rig primarily for gaming, but I do burn a lot of CDs/DVDs.
Processor: Athlon 4400+ dual core
Heatsink: Stick with stock? Better alternatives? [Want options for the future if I wish to OC..]
Power Supply: ENERMAX EG851AX-VH(W) FM 660W Used Enermax in my old PCs, been reliable albeit expensive. Any credible alternatives..?
Motherboard: Looking at ASUS A8N-SLI Premium ATX - Anything recommended over this?
CD/DVD burner: No idea whatsoever here. Never been good at picking these, just want something fast and good quality. I am about 4 years behind on these.
Graphics Card: XFX 7800GTX 256mb [Wondering if I should go with this or the MSI one with a smaller price tag?]
RAM: CORSAIR ValueSelect 2GB (2 x 1GB) Should I opt for the more expensive ram Corsair offers?
Hard Drive: Maxtor DiamondMax 10 300GB (Alternately I am just thinking pulling one of my 100gig HDs from my old PC, cache on 'em is 8mb though instead of 16 here, to save cash.)
Sound Card: My old Soundblaster Audigy Platinum. Is it too outdated?
Case: Not sure on this one. Looking at http://www.geeks.com/details.asp?invtid=TAC-T01&cat=CAS but am open to anything. Personal preference leans more towards black or metallics. Suggestions?
Will be air-cooled, still looking around for good quiet fans. (Suggestions?) I would like to cut costs wherever possible, I will be waiting for GTXs to go down to go SLI..
Thanks for any input,
-charger69 :)
If your looking to replace your stock HSF, I personally like the Zalman ones. They are the perfect blend of performance and quietness.
The stock HSF on the X2's are supposed to be quite good, but if you want some really good/quite cooling you should look into these: SI-120, Zalman 9500, or the Big Typhoon.
I'd look at these for as alternative PSU's: Antec TPII 550W, OCZ Powerstream, or PC P&C's 510W SLI. All of them are very good quality, though my personal favorite would have to be the OCZ because of it's very high price/performance ratio.
The motherboard is good. I'd stick with it.
This is a good burner for the money.
I wouldn't get either of those brands for the GPU. Both the BFG and eVGA cards have lifetime warrentees, which would definitely make them worth a little more.
I also woudln't get Corsair RAM. Eclipse would definitely know more about it than I would, but here're my recomendations: OCZ 2GB Platinum or G.Skill Extreme 2GB.
HDD is good, as well as the soundcard IMO.
There are a ton of good cases out there, so here's just a little sampling of the better ones. Antec P180, Gigabyte Aurora, CM Centurion 5, and the CM Stacker.
