Ok so here's the scenario:
There's 2 computers in one building and 2 more computers in another building about 50-60 yards away across an alley. The buildings are in an industrial area with a bunch of wharehouses, they're leasing suites in 2 of the buildings. They also have 2 more computers in the field that they want to be able to connect to the network remotely. They expect to grow to about 10-12 computers in the next 2-3 years, with about 6-8 of those in the offices and the rest in the field connecting remotely. The main priority is file sharing and seting up a quick and easy back-up solution for all those files.
So I've been doing some research and so far what I have found is pointing me in the direction of a file and vpn server. So far what i have come up with is to set up a server in one of the buildings and have it host all the company files and to handle all the vpn connections. I would set up vpn connections to the rest of the computers including the ones in the other building. I'd also set up a RAID 5 configuration on the server for redundancy.
One more thing I forgot to mention is that both buildings already have a DSL connection. That's actually how they have been sharing files, they e-mail each other whatever files they need, lol.
As far as budget goes, they would like to keep the costs down as much as possible, they didn't really specify an amount though. I would like to keep it under $2000 if that's possible, that might even be a little more than they were thinking. I definitely don't want to cut any corners so if my proposal comes out to more than that then they'll just have live with it. Basically what I'm looking for is a setup that's easy to configure but also really easy to manage since none of them really know anything about computers and as cheap as possible.
I just need to know if I'm on the right track or not, it's been hard finding info on setting up a network with this type of a configuration. Any suggestions would be greatly appreciated. Also recommendations on the actual hardware and network os would also be greatly appreciated. Thanks in advance and any constructive criticism is welcome.
