- Jun 20, 2010
Hey guys,
I've been reading these forums like crazy for the last week or so, but now I'm at the point where I need to ask some questions and try and get a little bit of help from some of you.
Long story short I'm just starting to build a DIY file server / NAS, and I'm after a little bit of help/advice on the best hardware to try and meet some of my goals.
I've used plenty of 'off the shelf' NAS devices before, but this is my first time building one from scratch, so apologies if I miss out or say anything stupid!
I'm figuring out all this as I go along!
Here's the story so far:
* I've got a Norco 4220 chassis on the way, which I want to use for 2 x RAID6 @ 10 disks each.
* It's a dedicated file / media server, so I really don't need anything super powerful in terms of CPU etc. [What sort of CPU speeds do you think I can get away with, without compromising the RAID performance too much?]
* I'd like to make sure that the drives can do a staggered startup, and also make sure that they can spin down / sleep when they're not being used.
* I want some good quality RAID cards, preferably taking advantage of the miniSAS ports on the 4220.
* Cost isn't an issue ... I'm more than happy to pay for good quality equipment ... but it DOES actually have to be WORTH the money!
So ... over to you guys then.
Is there anything you can suggest / recommend which might help me on my way a little bit?
Much appreciated!
--David
Much appreciated!
--David
