Need Suggestions for UV Colors...
MaXXimus
Ok so Im going with 3 loops in my build and Im really having a difficult time with what colors I want to use. I was thinking:
All my rad and case fans are going to be led blue
1 - Each loop a differant color blue, green & ?
2 - All loops the same color blue or green ?
3 - 2 loops green & 1 loop blue ?
4 - 2 loops blue & 1 loop green ?
And what about cold cathode... I dont know what will give the nicest effect, going with all UV or if I should go equal parts UV + equal parts (Insert Color Here) For example if I went with say all green uv coolant I was going to do 1UV +1Green near the side panel window on top and bottom and also the same config on the top and bottom on the other side.
Suggestions and/or input would be greatly appreciated.
Depends on your taste... We can't really choose colours for you.
If it were up to me, I'd do red/orange/yellow... or Blue/red/purple or something like that.
But, if you're using UV anything, don't mix cathodes. Go UV only. And get the 4" ones, they're twice as bright as the 12" ones for their size (same amount of luminosity, but in 1/3 the space!)
