Need Suggestions For A New Mobo
john10687
I got a...
AMD Athalon XP 2500+ @ 1.82 GHz
Asus Via KT600 Series Motherboard
Geil 512 MB PC 3200 Ram
Seagate 7200 rpm 120 GB Hard Drive
Radeon 9600 pro Video Card
Im looking to upgrade my mobo because i have 2 sticks of Geil 512 MB PC 3200 ram but my mobo only supports one(so i figure since when i try to hook up two in any socket order, the pc crashes). Im looking to spend no more than $130, what would you suggest?
That baord would be alright, but I think the NF7-S2 does not have a multiplier control, although this is just from what I read. i bought a abit nf7-s rev 2.0 from www.zipzoomfly.com about a month ago and it only cost like $85 w/ free shipping, so you might wanna look at that
If you want to spend around $50, I'd strongly reccomend Shuttle's AN35N Ultra
If you need firewire, SATA, or Soundstorm, then I'd goto the NF7-S or A7N8X-E Dlx.
DFI LANPartty nForce 2 Ultra Revision A.
Cheaper than the B, just as good. I've been running mine since November 2003 and I have had no problems with it. It's a great overclocker to. Pretty much as long as you get an nForce 2 Ultra Chipset you'll be good.
If you can't tell I'm an nVidia !!!!!! (when it comes to chipsets) :D
Could you give me the exact link for that one?
have you had any trouble with that one cause my mobo now isnt a duel channel and is a via chipset and it sucks plain and simple. The bios are awful for oc and i have had problems with the pc just restarting itself on many occasions. Its not heat related or power related cause i have 4 fans in good locations and i got a new 400w power supply.
