Need suggestion for new processor
nuggetz
Sup folks, I'm a big gamer and I'm looking to make a small upgrade to my rig. I currently have a p4 2.8 GHz and was looking to go AMD this time. I don't have that much money to spend like I usually do so I cant go top of the line X2 or anything at this time. I'm going to keep my nVidia 6800 AGP I think unless a PCI express board is necessary.
Anyway, what's going to give me a significant performance boost in DX9 games? Which CPU would you recommend. I was thinking of the lowest dual core becuase I do lots of multitasking too. What would you guys recommend.
Thanks
if you can find a 144 Opteron I would get one... Chea great OC
I think you need to be more specific that I don't have much to spend on it, give a hard number as that could drastically change what hardware would be recommended for you. I can piece together an amd64 3200 s939, mobo, and ram for under $500, and probably a vid card in there too.
for 350 you get an X2 3800+, that's if you want dual core (who doesn't). Or you can go the cheaper single core route and get that opty.
