Need Suggestion About SSD for Boot Drive
Lately, I want to replace my old boot HDD, which has begun making a strange noise, with a new boot drive. But I am confused to choose between a new HDD or switch to an SSD. At first I did not think about replacing my old boot HDD with SSD at all, but after I watch this video, I became interested in using the SSD: http://www.youtube.com/watch?v=-sA0zmhW7Fg
My first question is: What brands and types are recommended to maximize speed? I had heard about Sandforce Controller for SSD from my friend, is SSD with Sandforce Controller is a good SSD?
Thanks before.
Sandforce (OCZ Vertex 2), Intel, and Marvell (Crucial C300) all seem to be very good these days, with Intel being the most tried and true, but somewhat slower in some benchmarks (probably not noticeable in normal use). Personally, I wouldn't have a problem using any of those as my boot drive, especially on Windows 7. I would choose from those three based on price for the size you need.
Realistically, you probably won't notice a difference in any of the current generation SSDs - they are all so much faster than traditional drives that the 2-5% difference between them is insignificant.
Going SSD was the single biggest improvement I made in any computer ever for an upgrade. You definitely want one but just need to decide how big a boot drive you can afford. IMO the 80gb ranges are a sweet spot, you don't feel cramped size wise.
Prefer the Intel/corsair drive or Marvell Crucial c300. Sandforce 1200 is good too if you are getting it without the OCZ part.
I recommend Intel X25-M. There are some that are faster in some benchmarks but in general Intel has things best "thought out" for worry-free longevity and long-term performance. They also happen to top performance at small, random IO which is the signature of a boot/OS drive.
You must be sure that your partitions are aligned, and run Win7 so that you get full TRIM and other optimizations for SSDs. If you install Win7 clean it will also take care of alignment.
Most of the "tweak guides" out there for SSDs are garbage - full of ignorance and misinformation. I suggest disabling "hybrid sleep" (so if you "sleep" the computer it doesn't write the hiberfile every time - only if you hibernate) and doing a quick check to make sure that your SSD is not scheduled for defragmentation (do not disable the fragmentation service or scheduled task).
Look into Link Shell Extension if there's anything you'd like to move to your SSD from your HDD but have it still look like its on the HDD (like the one of your twenty games that you actually use every day).
Thanks for all your suggestion, but I already decided to buy an OCZ Vertex II SSD.. Hope this will be the right choice ..:)
You'll be hating how slow your optical drive is, but loving the SSD once it gets a hold of the data.
Speaking of which, any information on when the next generation of SSD's will start to appear (I'm sure it's all rumors at this point)?
The fastest boot drive available right now is the Corsair Force F40. Has 40GB capacity, standard for a boot drive in its price range. It keeps up with the higher capacity drives in reads and loses ~5-10% in writes. It is faster than the x-25m in all cases except for 4k random writes in iometer because of the insanely high IOPs. After rebates, it costs the same as the Intel X-25V on Newegg, but gets 5x write speed and 60% faster reads.
Corsair F40@Newegghttp://www.newegg.com/Product/Product.aspx?Item=N82E16820233130
Review of F40 @ Storage Reviewhttp://www.storagereview.com/corsair_force_f40_review_40gb
