I had the altec lansing 2100 and its been discontinued
It has a subwoofer where you connect the speakers into, and the only way to turn on the subwoofer for the speakers to get power is with a control that you plug in.
The control died on me, I was wondering what can I do to be able to use my speakers
They are pretty old speakers and cheap ones at that, so any cheap alternatives would be best
Thanks for help
Thanks for help
