Need soundcard with XLR inputs
bobsaget
What is the cheapest way to get just one XLR input on my PC?
I don't want to just use an adapter.
I saw the M-Audio FastTrack for 99 bucks. If this is the cheapest/best for the money out there, I will get that.
I just thought that I'd run it through you guys first.
I'm looking for something cheaper than 100 bucks. (external/pci)
Thanks. ;)
I don't think you'll beat that M-Audio card, particularly if you consider quality.
for the money you can't beat that M-Audio card. if you want the best though get the lynx two which costs just 1k.
